Just more reassurance for long term...
I had the same question when I got the Thermalright Bolt Thru kit for mine, and yes as mentioned above snug is good!
If it's not wobbling there's nothing to really worry about.
The Vendetta 2 keeps my Q9550 cores at roughly 28-38 (lowest and highest cores mentioned) celcius at idle.
