Old November 10, 2008, 09:32 AM
Evylldemon's Avatar
Default new cpu heatsink
I'm putting together a new gaming rig and was looking for some advice on a good heatsink to get. I plan to overclock but nothing hardcore.
Setup:
Antec P180 black mid tower
E8400 (may OC to 3.5ish)
ASUS P5Q Pro
G.Skill 2x2GB PC2-8000 DDR21000
EVGA GTX 260 Core 216 626Mhz 896MB 2.1Ghz
Options:
Sunbeam Core Contact Freezer
OCZ Vendetta II
Sunbeam Tuniq Tower
Also a friend has a thermaltake passive cooling heatsink but I don't remember which one.
Anyone familiar with these parts can recommend which would be the best? They are all roughly the same price so I'm mostly looking at what would fit best into my case with the P5Q
Thanks!
-G
Old November 10, 2008, 09:48 AM
misterd's Avatar
Those are all great choices, anything with the HDT technology will serve you well. Another one to consider is NCIX.com - Buy Xigmatek HDT-S1283 Direct Touch 3 Heatpipe Heatsink AM2 LGA775 S754 S939 S940 W 120MM PWM Fan - HDT-S1283 In Canada. same idea as what you have listed.
| i7 920 / Noctua NH-U12P / Asus Rampage 2 Extreme / 24GB Corsair Vengeance / Asus HD5870 / Corsair 600T / Corsair HX850 / Intel 520 240GB |
| X2 5000+ BE / Passive Scythe Ninja Mini / Gigabyte MA78GM-S2H
/ 4GB G.Skill Pi / Fractal Core 3000 / Corsair CX430-M / Intel X25-M 80GB |
| i7 2700k / CM 212+ / Asus P8Z68 Pro-M / 8GB Corsair Vengeance / Antec SLK3700AMB / Seasonic M12-II 430W / Samsung 1TB |
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old November 10, 2008, 09:55 AM
add a bolt-thru kit with the xigmatek and its simple to install, provides great cooling and the rest
Xigmatek version
NCIX.com - Buy Xigmatek ACK-I7751 Crossbow Mounting Kit for 3 Piece Heat Pipe for HDT-S963 HDT-S1283 RS-S1283 - ACXTACK-I7751 In Canada.
thermalright (need to removie pushpins yourself)
NCIX.com - Buy Thermalright LGA775 BOLT-THRU Kit for for Ultra 90/120 & HR-01 Retail Box - BTK-LGA775R In Canada.
Intel Core 2 Duo e8400 @ 3.8GHz
Mushkin Ascent 1x2gb
Asus P5N-D
BFG Geforce 8800GT OC SLI (folding issues...)
WD 500GB
NZXT Apollo
OCZ Vendetta 2 w/ Bolt-thru kit +Scythe S-Flex F
Syncmaster T220, Razer Deathadder, Lycosa Mirror Edition, X-240 speakers
Old November 10, 2008, 12:02 PM
paphman910's Avatar
OCZ Vendetta II has a good fan. I would also get the 775 bolt through kit from Thermalright and remove the pushpins.
Paphman910
Old November 10, 2008, 02:41 PM
Evylldemon's Avatar
After reading as many reviews and comparisons as i can there doesn't seem to be a common consensus about which of these are better:
OCZ Vendetta II
Xigmatech S-1283
I'm sort of leaning towards the OCZ because it seems like more people have this one based on signatures on this forum. I would get the thermalright bolt-thru kit and remove the push pins. And I already have some MX-2 paste.
Also I'm a fan of the OCZ brand name so I'll probably end up going that route unless someone can convince me otherwise.
Thanks for the help!
Old November 10, 2008, 02:57 PM
SugarJ's Avatar
Acording to the review on this very site:
OCZ Vendetta 2 CPU Cooler Review
The OCZ very slightly outperforms the Xigmatek. They are almost identical to look at. Any one of the three will do you fine.
Old November 10, 2008, 03:03 PM
Neolithium_Wpg's Avatar
Vendetta 2 & 1283 perform ridiculously close together, but in either case they both work very well. The push pins are horrible so the bolt through kits are definitely advisable.
MacBook Air 13" (2011) | Blackberry Bold 9900
A Veteran, whether Regular Force, Reserve or Retired- is someone who, at one point in their life, wrote a blank cheque made payable to the Dominion of Canada for an amount of "Up to and including my life"
-Author Unknown
