Originally Posted by mchutch Apply MX-2 to the stock and have a 120mmfan on it. My GTX 260 Core 216 SC edition is idle around 40*C and load @ 55*C. I've even OC'd it even though it's Superclocked (575 stock, 626 SC and mine is 666. These temps are pretty good for air, to spend $50 or more on a marginally better is not too worthwhile. If you want to spend and get better cooling for gtx 260/280 go with water. |
That's good advice for using the stock heatsink, however I have been fitting aftermarket heatsinks to most of the cards I have had personally and to other system builds for several years now. The typical 15-20C reduction in load temps and the noise reduction are well worth the cost. As for going with water, I have no plans to go there, we are talking about a lot more than 50 bucks to do that
But kudos to those who have such exotic cooling, I have seen systems that have terrific water-cooling setups with all the expensive parts, both EVGA and DangerDen have nice blocks for these cards.
Originally Posted by matsta31 Just curious, did you have to take out a hard drive bay for the GTX280 to fit in your mini ?
and wartercooling a mini is quite and adventure ! |
Actually, I removed both hard drive bays and the shelf between them (it was riveted on) as a small modding project for my own warped preferences. I only use one hard drive and it is mounted near the bottom front of the case. As for the 280, I think you have to remove the lower hd bay to fit that beast in, mine has tons of space with the bay removed.
Installing a good watercooling system would be an adventure. Not my cup of tea, I am happy with high-end air cooling.
Originally Posted by Eagle Eye There isn't alot out there Retro, like you I am patiently waiting for something to surface to. I am glad thermalright hasn't released the HR-03 GTX if there has been problems with overheating it all makes sense now why its still a preview on the website, its been like that for months now.
EE |
Right, it looks like a question of waiting until TR gets these coolers out. I e-mailed Thermalright Support way back on June 22 and asked when they would be releasing the HR-03GTX, they replied that it would be "hitting the market in early August."
That makes it three months overdue now. Some guy from Sweden told me on XSF that there was an overheating problem with the new HR-03GTX installed on the 260/280's. Seems odd to me but it would explain the long delay.
As much as I like Thermalright's products, it is still unfortunate that no other companies are making an alternative to the HR-03GTX.
I did sent TR another e-mail about an eta, not that it did any good before
