-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   Scythe Ninja Plus Rev. B (http://www.hardwarecanucks.com/forum/air-cooling/1150-scythe-ninja-plus-rev-b.html)
BALISTX May 5, 2007 07:04 AM
Will the Ninja Plus Rev. B be tall enough not to interfere with using the first ram slot on a DFI LANParty UT Ultra-D?
alleycat8675309 May 5, 2007 10:04 AM
2 Attachment(s)
I just intalled one on a Sapphire ATI Crossfire mobo. *EDIT* The fins do clear the ram slots 1 & 2 ...(I'm not sure if a ram stick could fit in slot 1). The fins partly blocks the cpu fan connector (between the fins and the blue ram sockets is the beige thingy) and the 8 pin 12V power connector (thick black cable at the top of the Noctua case fan). Also if I install a fan (a Antec P150 case), the frame of the fan will be touching and pushing down on the ram in slots 3 & 4. I've left the fan off for now and the temps are the same as before on a socket 939 3700+.
enaberif May 5, 2007 11:28 AM
If you add the fan to the ninja you lose the 1st slot on a lot of boards including my asrock 478 board and a intel bx2 board.
