Old October 12, 2008, 06:01 AM
Mr. Gruntsworthy's Avatar
Default OCZ Vendetta II temps
My E8400 45nm Wolfdale 'cpu temp' idles at 30C, and has hit 41C under moderate load (haven't tested full load yet).
Core 0 idles at 35 to 38C (varies depending on clock speed)
Core 0 has hit 48C under moderate load.
Core 1 idles at about 36C to 38C (same, it varies based on clock speed)
Core 1 has hit 42C under moderate load.
I have the EPU-4 energy saving feature, and during times of low/no activity my cpu will downclock itself to 2GH (roughly) to conserve power, then powers back up to 3GH during load.
I'm just wondering; what would you rate the temps I'm getting? I'm using the OCZ Vendetta II with the push pins (planning on getting mounting brackets as soon as possible), and OCZ Freeze thermal paste (of which I got a nice, thin, even spread).
If you want, use a scale of 1 to 10, 1 being too warm and 10 being ice cold.
And I'm well aware that i'm not getting 100% cooling from the vendetta II, im guessing the push pin system doesn't allow for a very tight press against the cpu, amirite...
MAIN RIG:
Case: CoolerMaster HAF 932
CPU : Intel i7-5820K 6-core @ 3.3GHz
RAM : 32GB DDR4 2400MHz (G.SKILL Ripjaws)
HDD : Main: 240GB SSD SATA2 (Intel) Storage: 3TB SATA2 (WD Green) Backup: 500GB External USB (Hitatchi)
GFX : Gigabyte GTX 970 4GB
PSU : 750W Corsair Modular PSU
MoBo: Asus X99-A
View : Acer H213H 21.5" @ 1920 x 1080 + random 4:3 monitor
Level/Game Designer, Programmer
http://mikeseguin.webs.com/
I run Durham 3D Printing, an online 3D Print shop!
Old October 12, 2008, 10:12 AM
Alwaysrun's Avatar
Looks like your smack on target dude. I just put my similar rig together last week and your numbers look average. If your using pc probe that Asus provided I'd ditch that as the readings are way off(at least they were for me).
Use Real Temp. Run as Administrator, once it's up hit Settings and Set TJ max to 100 100
techPowerUp! :: Download Real Temp 2.70
Intels thermal specification for the E8400 CO stepping is 72.4C
Intel® Core?2 Duo Desktop Processor E8400 - SLAPL
and for the EO stepping it's 74.1C
Intel® Core?2 Duo Desktop Processor E8400 - SLB9J
Old October 12, 2008, 10:41 AM
Temps are fine.
Old October 12, 2008, 01:39 PM
Im in the midst of encoding a video, using my processor almost fully. So far I havent hit core 0 over 49C.
MAIN RIG:
MoBo: Asus X99-A
Old October 12, 2008, 04:39 PM
Dar_ell's Avatar
Nice, my temps are like 3-4C higher then you. Hopefully my bolt thru kit comes in by tomorrow.
"My brother is dead. He's not here Anymore. But on my back, and in my heart...He lives on in me. I will make a hole through heaven itself, even if that hole becomes my grave. As long as I break through, I will be victorious.Who the **** do you think I am?"
Old October 12, 2008, 07:00 PM
Man, i thought i didn't get it done properly!
Strange...
can someone explain to me then, how my Intel Core 2 Duo E4600 idles at 30C with a stock cooler?
MAIN RIG:
MoBo: Asus X99-A
