Old October 9, 2008, 01:17 PM
BALISTX's Avatar
Default Fan Grills
Does anyone know any place that is selling 120mm Black Wire Fan Grills and have them in stock.
No place here localy has them and I checked NCIX and they don't have any instock and looks like they are not carrying them anymore. All I can find is the 140mm ones.
:help:
Heatware
HWBOT
Old October 9, 2008, 01:46 PM
I guess you are very right, I can't seem to find any either.
Old October 9, 2008, 01:54 PM
JD JD is offline
Petra's Tech Shop, Performance-PCs, and probably more US sellers...
I've found that any kind of real modding supplies are nearly impossible to get within Canada.
Old October 9, 2008, 01:56 PM
3.0charlie's Avatar
Steel Grills : Performance-PCs.com, ... sleeve it and they will come
A few here...
Hydro-Quebec is salivating...
Old October 9, 2008, 02:16 PM
Just as Jdrom and Charlie mentioned, I was going to suggest Performance-Pcs myself, but thought you'd find it bitter..
Old October 9, 2008, 03:11 PM
MpG's Avatar
MpG MpG is offline
You can add Sidewinder Computers to that list too.
Old October 9, 2008, 03:34 PM
JD JD is offline
Petra's is $1 less though and shipping might be cheaper.
Old October 9, 2008, 06:14 PM
3.0charlie's Avatar
Good call: 120mm Black Metal Fan Guard
Black 120s.
Old October 9, 2008, 06:19 PM
RP Electronics too
Fans : Fan - Guards
Old October 9, 2008, 06:30 PM
BALISTX's Avatar
Thanks guys. It's what I feared looks like I'm going to have to order them from the U.S.
Looks Sidewinders is the cheapest.
$7.50 USD for 6 grills + $2.86 First Class International Shipping.
Heatware
HWBOT
