Old October 7, 2008, 10:57 PM
Terrance's Avatar
Smile Arctic S1 Rev.2 and CrossFire?
As I mentioned in my post here: Best Gaming Rig Under $2000?
I'm running 4850s on CrossFire, have 2 quick questions:
1. Is it worth it to spend $60 to get 2 Arctic Cooling S1 Rev.2 for my 4850s? My concern is, I got 80 degree in-game temperature, is it that bad for my cards that I should spend a extra $60 on them?
2. If I decide to go with the Arctic S1s with 120mm fans, since the CrossFire bridges are pretty short, are they gonna fit?
Thanks a lot.
Old October 7, 2008, 11:10 PM
misterlarry's Avatar
I saw an over 25 degree drop in GPU load temp and 10 degree case overall drop just by using a passive AC Accelero cooler on my 8800GTS. If you have good air flow, I think it would be worth trying them without fans, or maybe just with a custom placed case fan. IMHO. Btw, welcome to HWC!
Asrock Z68 Extreme3 Gen3 - Intel i5 2550K @ 3.4 GHz - Corsair H80 CPU Cooler- 4x4 GB G.Skill Ares DDR3 1600 - EVGA GTX560 Ti
1x120 GB Mushkin Chronos Enhanced SSD - 1x500 GB Seagate Hybrid Momentus - 2x500 GB Seagate Barracuda 7200.11 - Pioneer DVR-212D - Antec P182 - Corsair TX650 - 22" Hanns-G - Windows 7 Pro 64 SP1
The world is your oyster. Shuck away my friend, shuck away!
Old October 8, 2008, 03:06 PM
Terrance's Avatar
Thanks Larry, I'm discussing this topic in my original post right now, seems like my only solution is to go with passive cooling... I'm using Antec 1200 case, I'm not sure how good is it gonna be for this purpose...
