Old October 7, 2008, 05:02 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Default Noctua U9 CPU Cooler Review comment thread
It is that time again! This time we are looking at an air cooler which may not be as large as some of the others we have tested in the past, but it certainly did not stop the Noctua U9 from performing admirably. While it may not have won any awards, it may just be the perfect choice for many consumers and is certainly worth a look.
On a side note: We have updated our charts so please tell us what you think of 'em!
You can read my review here: Noctua U9
Hope you enjoy it!
AkG
Old October 7, 2008, 07:13 AM
Well not a bad cooler, it peforms pretty ok on the dual core cooling. Nice review AkG, I would love to see this cooler go head to head with a Ultima 90, just to see which one is worth it.
Great review as always. :)
Old October 7, 2008, 08:28 AM
AkG's Avatar
AkG AkG is offline
Thanks miggs78.
As for your question an ultima90 would probably win, as it can accommodate a 120mm fan. i.e. its wider and thus has more surface area for cooling. This combined w/ more cfm from a 120mm fan (with more static pressure) would result in lower temps...BUT since the ultima 90 is bigger the U9 would win IF space was a concern ;) It really all depends on what you are looking for.
Old October 7, 2008, 08:35 AM
Eldonko's Avatar
GJ AkG!
Old October 7, 2008, 05:54 PM
Dashock's Avatar
Great Review AKG lol im still waiting on a faster NFP-12 1300rpm can be pushed further say to 1600 rpm it would be a killer fan. Anyways great review
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old October 7, 2008, 06:57 PM
Aah!! thanks AkG, I wasn't aware of that, any cooler that can accommodate a 120mm fan, can 90% of the time beat any 92mm fan cooler.
Great information.. :)
Old October 7, 2008, 07:07 PM
Dizz's Avatar
Smile
I’m sorry to go against the grain but as far as CPU Cooling Reviews go I believe that it was on par with what is commonly done but it doesn’t even touch the lofty standards set by your Motherboard Reviews, as Hardware Canucks Motherboard Reviews are second to none.
With CPU Coolers, virtually all reviews test the obvious things such as Cooling Effectiveness but what about Noise Levels, Physical Fit or even Cooling Redundancy.
Personally, I would like to see you guys raise the bar; if a Cooler can accommodate a second fan then why not fit one? Surely I can’t be the only one who thinks that Cooling Redundancy is a critical factor when selecting a CPU Cooler?
From this perspective it would have been very informative to see the Cooling Effectiveness & corresponding Noise Levels, under some of the following conditions:
1.Two fans Push/Pull operations
2.Simulated failure of Push (Pull left in place)
3.Simulated failure of Pull (Push let in place)
4.Simulated failure of both fans (both left in place)
Finally on the subject of Physical fit you should have at least mentioned the extensiveness of Noctua’s Motherboard Compatibility Lists, many aftermarket HSF suppliers don’t even bother to supply such a list. Noctua.at - sound-optimised premium components "Designed in Austria"!
IMO Reviewer should be both revered & despised by Manufactures, thereby driving innovation; in contrast a mediocre review that in many parts reads like an Advertorial, serves no one. What first attracted me to your site was an incredible Motherboard Review (wow you guys broke out a multimeter & got busy, kudos ) & I want to encourage you guys to pursuer that same rigorous standards in all your reviews. After all we are Tech Enthusiasts aren’t we? So less advertorial & more testing... please.
Anyway, that my perspective & in the end I doubt any additional testing would have changed your conclusions but it would have IMO given your article the feeling of a genuine & rigorous review.
OK, so let my roasting begin
Regards, Dizz
________________
MoBo:
Asus P5Q-Pro
OS: WinXP Pro_SP3
CPU: Q6600 - 3.6GHz 8x450 - 24/7 Stable
VCore: 1.45v - BIOS Setting
HSF: Ultra 120 with NF-P12 Fan x 2
Temp: TCase 41c Hotest Tj 62c
GPU: HIS IceQ3 Turbo HD3870
Temp: Celcius 29-36 Degrees - Idle
Disp: Dual 19" Standard 1280x1024
Old October 8, 2008, 09:11 AM
AkG's Avatar
AkG AkG is offline
Meh.
Some people would complain no matter what we do.
I usually do test w/ 2 fans, but it in this case it wouldn't have been germane to the this review nor help the intended customer of this review decide if the U9 is right for them.
While fun, catastrophic failure testing serves little real world purpose. NO air cooler will work properly with a dead fan (more importantly how often does THAT occur in real life let alone TWO).
I mention in all my reviews how loud a fan is. It is subjective, deal with it. Of course, if you wish to donate the necessary equipment I will happily use it ;)
Annoying the mfg'ers (which I have done in the past...and will do in the future) was not called for in this review, nor would it have been fair. What purpose would it have served?
60 hrs of testing gave me a good feel for this item. I stand by my review.
Saying I'm not "genuine & rigorous" in my review tells me a lot about you.... 'nuff said.
Now I'm gonna go back to testing my next item....a very sweet CASE which has been mentioned in the forums.
/cough/ Massive stock fans...great WC'ing options /cough/
Old October 8, 2008, 10:16 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Just to add to what AkG said, no one here should worry about being flamed for their comments about a review. There is a reason we have these comment threads and that is to have an open dialog with the community where you guys are able to voice your opinions no matter how negative they may be.
While it is always nice to have praise, everyone knows that constructive criticism often leads to us better understanding what you guys expect. It is a way to improve the reviews since no review (be it mobos, GPUs, enclosures, etc.) can be perfect as there just isn't the time for us part-time reviewers to touch on even close to everything. Don't worry though, everything you guys say is filed away somewhere in the review staff's heads and will be used in the future.
That being said, I believe that our CPU cooler reviews stand out among much of the competition since AkG is willing to put the time and effort into testing the coolers out on two seperate chips and at different overclocks as well. Naturally, with 50+ hours being dedicated to one review there will be some things that the Editorial staff has to cut so the reviewer can move on to other products. I am sure that if I gave AkG an unlimited amount of time with a product, he would come out with the mother of all reviews but with the number of manufacturers who want their products reviewer by us, I have to make sure the time is divided up evenly from one review to the next. It is a constant struggle on my part to make sure the reviewers have time to adequately evaluate the product they have while making sure the article comes out in a timely manner. If it doesn't it will be pretty much ignored since there are competing websites who will already have their reviews out.
Phew. Ok, I hope that explains things a bit better.
Old October 8, 2008, 11:18 AM
MpG's Avatar
MpG MpG is offline
Good review again. I'm still not sold on the validity of the "$/degrees" school of mathematics, but pay no attention to the watercooler...
Surprising that the smaller fan is that much louder than the 120mm variant. I would have expected the smaller size to compensate for the increased rpm, but obviously not.
Not that you don't provide enough pictures as it is, but if the heatsink base is bad enough, laying a razor blade across it and photographing the light leaking underneath makes for a pretty vivid shot.
