Old October 2, 2008, 08:05 PM
Question Question about fan controllers…
Still not used to this site fully hope this is in the right place if not I do apologize in advice….
I was looking at getting a fan controller for my antec900 but all my fans are the Big 3 pin connectors (see picture) If I buy some adaptors (also pictured below) will the fan controller still work on my fans?
The pictures are not mine I am just using them for reference
Old October 2, 2008, 08:12 PM
MpG's Avatar
MpG MpG is offline
Not entirely certain what you mean by "Big three pin". Are you sure you're not talking about the 4 pin connector?
Old October 2, 2008, 08:14 PM
CMetaphor's Avatar
Quadfather
A fan controller Should be able to adjust the speed of the fan if you use a Molex (the larger connecter, normally has 4 pins) to 3-pin adapter to your fan controller. Be warning though, that a "more advanced" fan controller with RPM reporting or an LED status light that varies according to the rpms of the fan Will Not Work. Otherwise, the fan controller should work just fine.
Old October 2, 2008, 08:22 PM
I was looking at this controler for my case NCIX.com - Buy AeroCool FP-01 5.25IN Flip Up LCD Display Fan Controller & Flash Card Reader with Front USB & eSATA - FP-01 In Canada.
.....since it wont work do anyone have any sugestions for one that would?:help:
Old October 2, 2008, 08:29 PM
CMetaphor's Avatar
Quadfather
Sorry, i didnt make myself clear. The fan controller will work, but the RPMs will read as zero or "Error" depending on the fan controller.
Old October 2, 2008, 08:33 PM
Well it still defeats the purpose of having that fancy one if 1/2 of the stuff won’t show up.....got any suggestions for one that would work as it is supposed to?
Old October 2, 2008, 08:37 PM
CMetaphor's Avatar
Quadfather
Either swap the fans out for standard 3-pin ones or get a more simple fan controller, like the Zalman MFC-1.
Old October 2, 2008, 08:38 PM
I dont mean to be obvious but that is what I am asking sugestion for?....just a simple one
Old October 2, 2008, 08:40 PM
CMetaphor's Avatar
Quadfather
And if you had continued to read.... Zalman MFC-1.
::: Zalman, leading the world of Quiet Computing Solutions :::
