Old September 28, 2008, 07:47 PM
Mulder's Avatar
Default Thermalright Ultra 120 Extreme
Does anyone know where I can find what liquid Thermalright uses in there heat pipes?
Old September 28, 2008, 08:58 PM
you can't.
Old September 28, 2008, 09:01 PM
werty316's Avatar
Originally Posted by enaberif View Post
you can't.
What he said.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old September 29, 2008, 10:39 PM
Mulder's Avatar
you can't.
I was looking for information regarding the thermal qualities of whatever liquid is in that heat pump/HSF. Does anyone know if the liquid in that HSF will freeze?
Old September 29, 2008, 11:35 PM
MpG's Avatar
MpG MpG is offline
I've never seen the substance used officially stated, although there are quite a few possibilities these days.
It's not so much that the liquid will freeze (although it might), but most heatpipe designs only work within a certain temperature range, up to a certain amount of wattage dissipation. In order to properly design them for processor cooling, freezing temperatures are almost always out of spec for optimum operation.
Old September 30, 2008, 12:37 AM
As far as I've read its not a liquid anyways its a gas.
And when the gas is heated and brought to the top and cooled by the fans its then converted into a liquid.
